Cooperman51
.040 Over
- Joined
- Sep 9, 2020
- Messages
- 55
- Ride
- Rocket 3 GT
Ive used the same as you exhaust wrap with heat proof silicone, did not work at all gets just as hot waste of time. Ive now found a better heat proof idea Allan Millyard used it on his Viper motorbike heat sheilds....The right side of the engine gets pretty warm during summer riding season, so to cure 90% of the heat I did the following.
Removed the stainless steel heat shields from all 3 headers and lined the insides with exhaust header wrap using silicone gasket sealer as an adhesive.
I cut the heat shield fabric to 1/8 in. smaller than the exact inside dimensions of the shields so u couldnt see the material ..
It works sooooo well, you can actually touch the shields when the engine is very hot, and its just warm to the touch. Triumph engineering, are u listening!!
Sonnie..
