2015 RAA 10 Details and headcount
@breeze will be there also, he will show up after work, he said he can find us no problem
[QUOTE ="Steel, post: 319861, member: 4209"]It is the size I have too. It also corrects the speedo almost right. At 100 mph indicated, the GPS shows 99 mph.[/QUOTE]
The 55 aspect ratio brings the rear axle up approximately a half an inch to where it is at least level with the front axle with the standard 150 tire. This improves your handling in the corners.
Now if you go to a 140 on the front tire next time, you will have a half inch less elevaton the front axle than on the rear axle and in my opinion better handling.
No real idea what any of food you cook is ... but it does sound delicious.
Ah H311... I'm hungry now. Holler at y'all latter
I run cobra and im using 38 front 42 rear
You left out average miles per day!!!
