Is that a typo on the manual?? just changed my oil and since i couldn't remember i checked the online manual, also valve checks every 40k miles??? is taht correct?? seems exessive long to me
I change mine at 5000. Or a little less if I've been riding the bike hard and I notice the lubricity change in the transmission. But then I even changed my 06 at 5000 when it was basically stock. Anyway to each his own I guess.
I change my oil every 5,000 miles. Do a valve clearance check every 20,000. Fuel filter gets changed at 20,000 also check neck bearing clearance at this time. Three valve clearance checks along with cam replacement and clearance has been good to go minus the first check. First check clearance was on the high side from factory. Spark plugs every 20,000 miles. Brake and fork oil replaced every 12 months. After my electrical problem i now check connections and clean all connections and grease every 12 months. The driveshaft and components get cleaned and grease every tire change. Tune ECU used every 20,000 for throttle body balance and so forth. 70,000 from 2015 to present and no major issues. Throttle cables and clutch cable replaced at 40,000 miles. No shop required or desired. Replaced neck bearings and races at 40,000 miles. Worn out from the piss poor grease triumph used during assembly. One of the best investments i ever made. plus Warp9's advice.
