05 r3 1500 miles stutter
Before any thing i would spray wd40 on the return springs on throttle bodies then wot and let go fast a few times.
Sometimes the rubber hoses or rubber caps get cracks and leak air into the throttle bodies makes it idle bad a d still runs good down the road.
Hth
Hth
I'll give it a go in the morning
They all look consistent, takes a while to color plugs, possibly a touch lean but pretty normal considering manufacturers must meet clean air standards. Kevin Fraiser suggested a shop to check, clean and flow test injectors, I sent mine to them and had them back within two weeks , was a good investment. I can probably find the address if you need it.
I've checked plugs, coils are all sparking, throttle body is great, and about 15 gallons of fuel with cleaner in it. Going to check fuel filter next
Write your reply...
