RAMAIR Filters bespoke Rocket-3 underclaw filter.
I am still having computer issues, with this site it now seems. On someone elses comp now. I really do not care who is a wanker or not or who thinks what looks cool or bad. I spent some of my time doing PERFORMANCE testing on the Ramair filter. I did not compare them with the underclaw K&N,s because I already know their limit. I did (as I said to Ruzz) compare them with the RU1770's back to back, same day same dyno, same operator etc etc. I found ONLY 1.2hp loss although about 2 to 3 ft lbs across the range. To my ( obviously limited) way of thinking, this is a very good result for those of you who wish to ride with the bearclaw still in place. The Ramair set up is well made, neat and will do 165hp on a stock engined Roadster with a Reband exhaust. As Russell quoted, I am fitting one to a bike in the next week or so, as well as my street cams,so that will be interesting. Not a direct comparison as this bike is a 2006 one with Jardine pipes. I have done enough of them to compare with others though. I believe there is nothing at all wrong with these filters, they are good in fact, and I am getting some in stock, for customers who want to retain their bearclaw. For the ones of you who want this stuff tested quicker, maybe buy one and test it yourself.
Straight to the point Nev, thanks. I think I will get tge ramair as it would be better than the under claw k&n's that I have.
Nev said "To my ( obviously limited) way of thinking, this is a very good result for those of you who wish to ride with the bearclaw still in place" & "I believe there is nothing at all wrong with these filters, they are good in fact, and I am getting some in stock, for customers who want to retain their bearclaw."
Thanks for the post Nev, as Mittzy said straight to the point, and gives us the information we want, think I also will go with the Ramair when I get the bike tweaked by you
My Humble Apoligies Chris if you had already read this, as it is wrong that is how I had it before I have since moved the plates to the underside of the stalks and used the original countersunk bolts, It looks a lot neater and still gives access to screen blots
Got it - Wont be strong enough for what I have planned - I don't think. I'll look after work.
Hanso what bulbs are you using in your clear indicator lenses. I spent $40 on chrome bulbs they look better than the orange ones but they look a bit pink from some angles.
orange LED's, clear to look at while not flashing but very bright orange when activated
Just reading your signiture Mitzy with 2 ts and realise you are already getting 163 ponies with triple K&N with reband exhaust o_O so what gives
