Journeyman
Check and adjust if necessary. I adjusted mine. Glad to hear that you got the bike. You won't regret it. Here you go....I am,pick it up in 2 weeks. Did your valves need adjustment @ the 20k service or just checking?
10k mile service - DIY (also, Spark Plugs Not Tight & Wire Boots Not Pushed On!)
Sharing my experience here changing the air and fuel filter and inspecting the spark plugs.  Refer to the manual for the basics, but here are things that may help, along with some very surprising discoveries I made...  1) Removing the tank  There are three things to disconnect besides the bolt...
				 www.r3owners.net
					www.r3owners.net
				A look at the 2.5 Innards - DIY 20K mile service, including valve clearance check and shim replacement
Part 1 This includes valve clearance check and shim replacement. Also air, fuel, spark plug and coolant replacement, and bleeding the clutch. This is a work in progress, so edits and further information to come...  Get the service manual here...
				 www.r3owners.net
					www.r3owners.net
