off to see the wizard..
Not if you’re retired and skint!! Oh that’s me!🤪
As long as you’re satisfied with the value for money, that’s all that counts mate.
Mine goes on the Dyno this Friday as I’ve fitted a Dave Platt exhaust and a K+N filter on the induction trunking. Just to smooth out the throttle, loose the Cat, Lamba sensor and the restriction on the gears. That going to cost around £450 (@$700US), so cheap compared to the work you’ve had done.
So what tyres are you guys running with these big power engines?
I had Carpenter do a bit more than the basic build...had the transmission sent out to Robinson to be undercut, including their billet 4th gear and had the head studded with Carpenter's custom studs. You also have to add in the cost of either their sidewinder or street rod custom exhaust pipe. I wanted the hayabusa clutch pack, but the beefed up clutch springs will do the job. At the moment I still have the OEM recommended size tires.
Three days after being picked up, my Roadster is finally home.:)
Just had my 2010 R111 Classic (Dave Platt exhaust + K+N) on BSD’s Rolling Road. Fueling sorted, Lamba turned off, gear limiters also off.
Now I know it’s not in Carpenter Racing’s league, but it’s amazing the difference just getting those few sorted makes! Pulls like it was supposed to do now!!
Doesn't need to be in Carpenter's league, or any other for that matter...all that matters is what you want and what you think. Enjoy the added ponies and torque!
