Zanx
- Joined
- Jan 25, 2025
- Messages
- 33
- Ride
- 2004 R3
I'll throw myself at you collective mecies and see what happens. I got the 2004 ready for a map upgrade today but I pulled the wrong fuse, it wasn't the light fuse, it seemed to power the OBD cable because the light went out. Amyhoo. found the right fuse, connected to Tuneecu on my phone just fine, started the upload then lost connection, now it won't connect to Tuneecu or spin up on the started button (and I'm assuming the pump should make a sound too, which it doesn't). Battery is at 12.8v so pretty ****ed good. Would a suddent ignition switch failure disconnect the ECU, fuel pump and starter?
