Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,964
- Location
- Ride
They are a listed part available from dealers world wide.
Which bits do you need?
I have a used one in my shed.
I replaced the whole lot as my Roadster's fuel guage was not working and it still doesn't so the sender was not the problem in my case. It did and still does have an operating low fuel light so i know it was still working when removed.
The Fowlers prices below are in Australian $, but you can select your own currency to display.
Fuel Pump & Filter - Triumph ROCKET III, CLASSIC & ROADSTER | Triumph ROCKET III, CLASSIC & ROADSTER Fuel Pump & Filter supplied next day (UK only) by Fowlers Parts
1
PUMP PLATE & CONNECTOR
T2400445
Share this part
BACKORDERNO STOCK
$213.50inc. VAT(£118.00) -
QuantityMinusPlus
2
SUPPORT ARM,FUEL PUMP
T1241092
Share this part
BACKORDERNO STOCK
$24.80inc. VAT(£13.70) -
QuantityMinusPlus
3
PIPE BRACKET,ASSY
T1241091
Share this part
BACKORDERNO STOCK
$21.34inc. VAT(£11.80) -
QuantityMinusPlus
4
Kit, Level Sender
T1241190
THIS IS NOW A MULTIPLE SUPERSESSION
Share this part
BACKORDERNO STOCK
$146.56inc. VAT(£81.00) -
QuantityMinusPlus
4
Level Sender
T1241089
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
5
BRACKET,REGULATOR,FUEL PUMP
T1241095
Share this part
BACKORDERNO STOCK
$16.09inc. VAT(£8.89) -
QuantityMinusPlus
6
Screw, Cap/Hd, M6 x 10, Enc, Raw
T3051069
Share this part
BACKORDERNO STOCK
$1.26inc. VAT(£0.70) 1
QuantityMinusPlus
7
FUEL PUMP,EFI
T1240103
Share this part
BACKORDERNO STOCK
$276.84inc. VAT(£153.00) -
QuantityMinusPlus
8
RUBBER,PUMP SPACER
T1241096
Share this part
BACKORDERNO STOCK
$5.97inc. VAT(£3.30) -
QuantityMinusPlus
9
Cushion, Fuel Pump
T1240846
Share this part
1-3IN STOCK
$6.69inc. VAT(£3.70) 1
QuantityMinusPlus
10
Strap, Retaining, Fuel Pump
T1240990
Share this part
BACKORDERNO STOCK
$13.85inc. VAT(£7.66) -
QuantityMinusPlus
11
Bolt, H/HD, M4 x 16, Slv
T3332130
Share this part
4+IN STOCK
$0.54inc. VAT(£0.30) -
QuantityMinusPlus
12
Fuel filter
T1240850
Share this part
4+IN STOCK
$71.48inc. VAT(£39.50) -
QuantityMinusPlus
12
Fuel Filter Muiltipack (5)
T1240004
THIS PART IS NOW OBSOLETE
Share this part
NO LONGERAVAILABLE
$316.64inc. VAT(£175.00) -
13
HOSE FUEL 45MM E25
T3620395
Replaces T3620094
Share this part
4+IN STOCK
$9.40inc. VAT(£5.20) 1
QuantityMinusPlus
14
Hose Clip, DIA 12.5
T3700089
Share this part
4+IN STOCK
$3.80inc. VAT(£2.10) 5
QuantityMinusPlus
15
O Ring, ID 10 x 2.0
T3600098
Share this part
4+IN STOCK
$1.17inc. VAT(£0.65) -
QuantityMinusPlus
16
Fuel Pressure Regulator
T1241093
Share this part
1-3IN STOCK
$80.51inc. VAT(£44.50) -
QuantityMinusPlus
17
Fly Lead, Fuel Pump
T1241097
Share this part
BACKORDERNO STOCK
$23.25inc. VAT(£12.85) -
QuantityMinusPlus
18
Cable Tie, 185.7 Long
T3700015
Share this part
4+IN STOCK
$0.91inc. VAT(£0.50) 1
QuantityMinusPlus
19
SEAL FUEL PUMP E25
T2401367
Replaces T2400447
Share this part
4+IN STOCK
$24.88inc. VAT(£13.75) -
QuantityMinusPlus
20
Washer, M5 x 15 x 1.6
T3551178
Share this part
1-3IN STOCK
QuantityMinusPlus
21
Locknut, Flgd, M5
T3350010
Replaces 3350010-T0301
Share this part
4+IN STOCK
$2.17inc. VAT(£1.20) 4
QuantityMinusPlus
22
WASHER,BANJO,M12 X 1.45
T3550128
Share this part
4+IN STOCK
$2.63inc. VAT(£1.45) 2
QuantityMinusPlus
23
BOLT BANJO M12X1.25
T1210258
Replaces T1210582
Share this part
BACKORDERNO STOCK
$11.86inc. VAT(£6.55) 1
QuantityMinusPlus
24
Bracket, Level Sender
T1241189
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
AUD prices shown are approximate as dynamic currency conversion will be applied during card payment.
Fuel Tank & Fittings - Triumph ROCKET III, CLASSIC & ROADSTER | Triumph ROCKET III, CLASSIC & ROADSTER Fuel Tank & Fittings supplied next day (UK only) by Fowlers Parts
1
T2400445
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
2
T1241092
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
3
PIPE BRACKET,ASSY
T1241091
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
4
Kit, Level Sender
T1241190
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
4
Level Sender
T1241089
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
5
T1241095
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
6
T3051069
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
7
FUEL PUMP,EFI
T1240103
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
8
RUBBER,PUMP SPACER
T1241096
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
9
Cushion, Fuel Pump
T1240846
Share this part
1-3IN STOCK
QuantityMinusPlus
10
T1240990
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
11
T3332130
Share this part
4+IN STOCK
QuantityMinusPlus
12
Fuel filter
T1240850
Share this part
4+IN STOCK
QuantityMinusPlus
12
T1240004
Share this part
NO LONGERAVAILABLE
13
HOSE FUEL 45MM E25
T3620395
Replaces T3620094
Share this part
4+IN STOCK
QuantityMinusPlus
14
Hose Clip, DIA 12.5
T3700089
Share this part
4+IN STOCK
QuantityMinusPlus
15
O Ring, ID 10 x 2.0
T3600098
Share this part
4+IN STOCK
QuantityMinusPlus
16
T1241093
Share this part
1-3IN STOCK
QuantityMinusPlus
17
Fly Lead, Fuel Pump
T1241097
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
18
T3700015
Share this part
4+IN STOCK
QuantityMinusPlus
19
SEAL FUEL PUMP E25
T2401367
Replaces T2400447
Share this part
4+IN STOCK
QuantityMinusPlus
20
T3551178
Share this part
1-3IN STOCK
QuantityMinusPlus
21
Locknut, Flgd, M5
T3350010
Share this part
4+IN STOCK
QuantityMinusPlus
22
T3550128
Share this part
4+IN STOCK
QuantityMinusPlus
23
BOLT BANJO M12X1.25
T1210258
Replaces T1210582
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
24
T1241189
Share this part
BACKORDERNO STOCK
QuantityMinusPlus
