RockOn
Turbocharged
- Joined
- Feb 22, 2018
- Messages
- 617
- Location
- Escondido, CA
- Ride
- '06 R3 Classic, '08 R3T, '15 R3 Roadster ABS
I've recently had a problem with getting my '06 Classic to idle. Unless I stayed on the throttle to keep the rpm's at idle(7-800 rpms?)it would immediately die. Here and other forums suggest replacing plugs, fuel pump, vacuum hoses, tpms units, re-programming via Tune ECM, replace or re-crimp wires to coils, remove stepper motor, adjusting stepper motor and on and on. I saw one guy, only one, suggest doing the 12 minute tune. That was by far the easiest thing to try first. I did and idle is now perfect. I get lucky once in a long while.
