What can I do about my azz end?
Doc, the one that Dave and I have are simple and work great. Plumb the wiring under the rear fender, solder everything and use shrink tube. I think it was about 200 bucks for front and rear. Make sure you order and change the turn signal relay, for the LED's don't draw enough amperage to operate the stock relay.
Also, there are different types of lighting modes. Mine are only turn signals on the rear. Dave has tail and turn in his. (He is rich). Remind me in MV and I will tell you how I know.
I took the stock turn signals and gutted the 'arms' to make the holders for my led's...worked a treat but had to take my time and be 100pc sure where i was going to do the cuts.
Got my led's from JP Cycles...they have a very good selection.
Nah, to much work.
I also have the one from EMP . very easy to work with and tightens it all up back there. I also installed "smoke" lens with brighter lamps. works great.
Dang , that sounds like mental effort and mechanic type work. I was hoping for an undo two bolts and replace with shorter bolts. Honestly I could manage that except for the soldering . I do not have the tool for that. I might just have to pay a man to do that.
BTW Ken if your thinking about criticizing me for being either lazy or stupid maybe when we meet again in MV I can show you how to save some money and work on your own teeth.
Now I will pay good money to see that
Mel buy the goodies and bring it to MV we will get it installed for you, now someone has to stay sober or we might get everything back to front.
If I don't already have it put on I will bring it. I do hate to press on friends to do projects for me and look pathetic.
BTW I'm torn about wether or not I need to re-degree the new cams in my bike. Nev says I could get a better low end torque but I may loose some of the top end hp. I'm going to have mu local guy do a compression check and see what we learn. Wish me luck.
Used a number plate bracket off an old Suzuki trail bike, mounted above the tail light with LED bolt/lights and a drill to mount the LED blinkers from Supa-Cheap.
I had the original one fracture and fall off while on a charity run. This way, when fully loaded there is only one Toll Camera in Australia that gets me .... I know from experience.
