Valve shim removal tool
@Gregger and @Rocket Scientist
After watching videos posted above wouldn't you use a magnet tipped stick now to extract shims rather than JUST the screwdriver?
The oil under the shim sticks them down pretty good. My magnet wouldn't do it. I use a screw driver to lift it a bit then blow air under it.
The problem with a "bigger" magnet is it is attracted to everything else around the shim, so diminishing returns.
Must get bigger shims.
Nah, F*ck shims, I want one of these Achates Power's 2.7-L opposed-piston engines now. Expected to achieve a combined 37 mpg on pump gasoline, and deliver 270 hp (201 kW) and 480 lb-ft (650 N·m).
Opposed Piston GCI/Achates Engine & Mazda? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Oh, which one of you can guess what SnapOn tool I cut up to make this? I'll give you a hint, it's from the 70s and I haven't used it for at least 20 years.
And the answer is......... a early GM door handle removal tool, used for window cranks also. Bought it when I worked in a GM dealership as an auto mechanic in 1975. Since most vehicles don't use these any more, it was a prime candidate for the tool having the hole and tangs close to ideal. Needed to heat the thing up to bend it since it was hardened.
I did use a rare earth magnet to snag some of the shims once loose but you needed to hold it with something to keep it from sticking to...... everything.
