I hope this is not taken as a stupid question but I recently saw a Rocket 3 Roadster with the cam cover squeezing out orange gasket sealer (it looked like silicone sealer) but I couldn't see a gasket.
The front timing cover was also squeezing out the same sealer.
The question I ask is:
Is this a fix for the cam cover leak problems and or is it a waste of time? I did not see a leak at the time but it looked pretty ugly.
Has anybody on this forum done this with a good result?
I did the job of removing and replacing the cam cover gasket myself, with a TON of help from this forum. I have a wicked thread here somewhere as I went along... On phone, lemme see if I can find it. Big job, so prepare to settle in for the long haul if you're an amateur wrencher like me. But it was oddly fun, slowly working thru it all.
Re: getting it to seal properly, the magic seems to be to follow the early torque spec of 10 (nM or ft/lbs? Can't remember....) vs the 12 the later service manual says. I did that when installing mine, and it's been great so far.
Good afternoon all! My '15 R3R has about 16k miles, and the stupid cam cover gasket has started sweating like a bunch of us have experienced I've discovered after using the Search tool. So, likely over my head, but feeling brave, I decided to tackle it. I've got the tank safely off, I've...
Does coating the gasket with silicone gasket maker help hold it in place?
My quick fix: The gasket started pushing out at the right front on mine at around 8,000 miles. I cut off the piece that stuck out and coated the area up with black silicone gasket maker, and nearly a year later, no leaks.
