Valve check at 20K
BigAl1952
Old Opinionated Bastard
Liberalrado,USA
2005 Rocket III
Hey Guys
I haven't had to do this yet but I know some of you do your own work. But surely there are some of you who take your rockets to the shop for the valve check. What kind of prices are you seeing? Boss went by one shop in Denver and they quoted him 1200.00. Man that's insane and I hope that isn't the norm or I need to find a money printer. Thanks Al
Bout 4-5 years ago I had mine checked and it was about $4-500 with one valve adjusted
There's hours of difference between a clearance CHECK and a clearance ADJUSTMENT......
Hey Guys
Had mine done for $600 in Cali and nothing is cheap here!
My estimate was $550 but a leaky fork seal and front brake pad added $1000. My fault for not asking how much for the seal and pad those are a couple simple enough jobs I could have done. I have the parts list and they do quite a bit for the $$$ at 20.k
I'm just glad that they changed it from 10k to 20k....
When was it changed? My manual still say 10, 30, and 50 thousand miles. Good to know if it's changed. If I factor in all the service intervals on my Harley when I owned it, it's still cheaper with the Rocket. Almost $400 a pop at the 10k and 20k points plus close to $200 at the 5k and 15k points. That $1200 by the 20k Mark.
I was informed by my dealer that the inspection sheets they recieved from Triumph had changed, the valve check was off until the 20k interval. To confirm I contacted Triumph and attached is a copy of the conversation.
Write your reply...
