Eddie
Standard Bore
- Joined
- Apr 17, 2016
- Messages
- 4
- Ride
- Triumph R 3 Rocket
Hi y'all,
New Rocket owner here. Just picked up an '09 with less than 3K miles on it this weekend. It was missing the left front turn signal bulb and glass; dealer has one on order and will be fixing that. As I left the dealership, my wife following in the car, the first time I used the turn signal it worked, but after than, nada. On the way home neither signal worked, nor did the horn or break light(brake light itself is on, just doesn't brighten when brakes applied). Easily determined that it's a single fuse that works all of them, but as soon as I replaced the fuse and used either turn signal, the fuse blew immediately. Replaced the fuse; horn...no problem, brake...no problem, turn signal...poof. So for the ride Sunday I just made sure I didn't use the turn signals and fuse was fine. Took it to the dealership yesterday and of course it's not covered under their 30-day warranty. However I did purchase a 2-year "everything" warranty, and will use it to deal with the problem if its something not easily fixed. Is it possible the turn signals are blowing the fuse because of the missing bulb, or is there something deeper going on?
