TuneECU Full Power map 20050-2
Slash193
Standard Bore
HI EVERYBODY!!
I use TuneECU and I want to download on my 2007 RIII standard (TORs and cat-bypass) the Full Power map 20050-2..
the map already loaded is the 20226, the only 20050-2.hex I found is this: http://www2.peelo.org:8080/rikunpaskat/20050-2Map-JeppisDynotettu-Tyhjakayntinostettu.hex.
My doubt is this:
the 20050-2 Ingnition Tables I1, I2, I3, I4 are similar to the 20222 (standard map), but so much different from my 20226 (about 1600-2600rpm)...
I can use this 20050-2 or I need to tune the Ignition Tables like my 20226?:confused:
What is the difference between 20226 and 20228 ignition tables??? Which one is the best???:confused:
THANK YOU SO MUCH!!!
