Gents,
I had the 020355 Tune uploaded from my Roadster. no problems.
changed to 100% secondaries on all gear, all rpm.
changed to new top speed.
downloaded to the bike, no problem. turned ignition off, waited 10 seconds and turned on in order to reset TPS as described in the manual.
I cannot get a respons from the ECU!
the flashing connection light in TuneECU does not change from red.
when I turn on the ignition, neutral light is not on/green, and the normal "hissing" sound form the bike is not heard, although the gauges goes from 0-max-0, engine oil and ABS lights are on.
I disconnected the battery as well for 10 minutes. no change.
tried to start the engine, not a sound of course.
I got no more ideas!
shouldn't I get the "recover ECU" option?
oh, when I turn of the ignition, TuneECU responds immediately that ECU is disconnected, so it _is_ connected in a way and needs a recover of some kind I guess.
have not seen that dialog pop up yet though.
