TuneEcu cable for 06 Keihin 1 ECU
RockyIII
Brazil
After an afternoon reading I have become very interested in using TuneEcu on my 06 model. But as I understand it, you need a 16 pin OBDII cable, so I was disappointed to see that my bike has the older Keihin 1 square style connectors.
Is there a different cable that I can buy or am I out of luck on the TuneEcu?
Thanks in advance
I've got an 06 as well and it has the correct USB plug. Are you looking at the cable receptacle located under the seat, beneath the tool folder, and to the immediate left of the battery protected by a flexible plastic collar?
Hi WSRVR,
Thanks for replying. I looked behind the small black side panel on the exhaust side of my bike as you can see in one of my pics, next to the two square relays. Is that the right place. There are two square connectors with loads of wires.
I hope this helps.
The correct connector is tucked into a clip right next to the battery on the left side. Remove the toolkit to see it. It is identical to every OBDII plug on all cars since '96.
Edit: Maybe not all cars in Brazil.
My '06 has the correct ODBII connector. Under the seat to the left side of the battery (as viewed if you were sitting on the bike). It has a black vinyl cover. You pull it up and turn it over to view the connector.
Thank you so much for taking the time to tell me this. It's right there under the seat, DOH! Cable now on it's way, thanks again.
