Tuneboy shows 0 degrees timing advance
kwimmer
Canadian West Coast
2008 Classic
Just got my Tuneboy and after a bit of getting up to speed, have solved a couple problems. Stuck stepper motor and TPS out of specs.
I am however not showing any ignition advance, as in 0 degrees at any throttle setting/rpm. on any cylinder.
Anyone familiar with this issue or what might be causing it?. This is just in Tuneboy and not tunedit. The bike is running fairly well, its a salvage that I have been working on.
Thanks
Kim
I don't think that is a feature for the Rocket's Kehien ECU in Tuneboy. Might email them and ask and wait for them not to reply to you.:D
I just installed a set of Jardines yesterday on my R3T. After loading a new tune today I went into Tuneboy to do the Reset Adaptives and noticed the same thing. So, I'd guess Brian is correct and it has something to do with the Tuneboy is interpreting the ECU data.
hey Kim ,pm me.
[ pm me, i can't send pm for some reason] slick rick. QUOTE=kwimmer;76332]Just got my Tuneboy and after a bit of getting up to speed, have solved a couple problems. Stuck stepper motor and TPS out of specs.
Thanks
Kim[/QUOTE]
