powernutty
Triumph
Finding my 20 plus triumph rocket gt suspension feels hard with riding. Special rear while riding on road surface.. anyone have any tips on rear adjustment for a bit softer . Ps my rear tyre pressure is set at 42psi ?
Also the front wheel when turning around corners if u hit a bit off unevern surface . Or like a crack in road surface . It's bloody ass nipping lol 😆
The manual specifies max soft settings for the rear for a solo rider (compression, rebound, and pre-load all dialed all the way out). "Solo rider" is usually manufacturer parlance for "someone weighing about 180 pounds/82 kg". Unless you're bottoming out, Col and Zig's rear settings are firmer than what the manual specifies, and your only option is to give dropped tire pressures a try or replace parts with aftermarket. Like papanorm, I'm also running 38F/40R.
