tank drain hole clogged?
CvSisinthehouse
Silver Spring, MD
You know that little hole to the left of the gas filler cap, supposed to drain whatever liquid builds up in there? Mine is clogged and I dont know how to unclog it. I stuck a large paper clip all the way down with no relief. I looked under the tank and didnt see any holes or drains or anything. My bike is not very old? Any ideas for me, thank you.
Not sure if you checked the lines or if the line in the tank is plugged. Easy fix the hole on the left of the tank
is a stesl line running to the front port under the left front of the tank
this is the drain/overflow hose that runs down a dumps behind the starter. Tge other on routes to the rollover valve stuff. You shoul be fine with compressed air. The steal line makes a sharp bend almost a 90 degree bend about a inch down from the full neck in the tank.
Much like the one in tbe view below
Wow, thanks dude. You didnt have to cut up your tank to show me! By the way I put 10 more discs on each Supertrapp last night, will see how loud we get. Rubber side down my friend.
