Hello, I'm looking to wire up a pair of amber running lights on my 2025 Rocket 3 GT - I plan to use the innovv power hub to provide power to the light only when ignition is on.
This power hub is wired to the battery directly, but has a trigger wire that signals whether the ignition is on or not
On my prior motorcycle (Harley), I tapped into the rear tail light (which was on only when ignition was on) - the power hub also delays power output for 10 seconds after ignition is on (to prevent overload).
On the Rocket 3, is there a wire under the seat that can be tapped into for this?
