Speedometer sensor for Rocket3
Dan
Standard Bore
2008 Triumph Rocket
I have a 2008 Rocket with only 10,000 miles. Speedometer suddenly just stopped working. All other lights and gauges are working fine. Speedometer and odometer are not moving at all. Is there a sensor somewhere I should be looking at or a wiring harness connection?
I would certainly take a look at wiring first - Calling @DEcosse - our resident electrickery guru. - But the older SPEEDOS are known to suddenly fail. The sensor IS however one option.
If it's the sensor you should get an MIL light and associated P0500 code - if no light, it may be the unfortunate fatal speedo issue.
