Slight coolant usage?
rocketboy3
bikes and boats
Michigan
2008 R3T
Does anyone have to top their coolant bottle off, mine seems to use a bit can't find any leaks, thanks for the help!
Check all hoses they do loosen up sometimes. especially the little one on the bottom of the thermostat housing.
Gday,
I found mine had an issue a few years ago exactly like your describing, couldn't find an actual leak but could often smell antifreeze. Found it was the top radiator hose not tightened enough, had the radiator pressure tested etc also after I found this just to be sure and it was all OK.
Never saw a drop on the ground at any time.
