Run Turn Brake Controller and LED's
Crazy.....
If you find the time could you post the parts list for this project?
I would appreciate as I am about to embark on this venture and you did such a nice job I might "borrow" some of the ideas. I think I might go with flexible leds in the bags though. Turned out great!!!
mutt
Sure.
I will say that I didn't intend to put these lights in the configuration they are in.
I would have bought the flexible LEDs if I thought about it.
I had to use some epoxy to glue the two 6" LED's to the reflector bracket.
Everything else is mounted with wire ties.
I'll get on that parts list for you.
Here you are:
Turn signal LED bulbs: BAU15s available from LEDLight.com
LEDLight.com LED Lights, LED Lamps, LED Bulbs Search Results
Ordered from Cruisercustomizing.com
Kuryakyn Run Turn Brake Controller (with Flasher)
KY-4710 Run-Turn-Brake Control -Metric
Signal Dynamics LED light bars
SD-2010 Univ. Light Bar 6" Black w/ Red LEDs x2
SD-2044 Univ. Light Bar 3" Black w/ Red LEDs Pair
18g wire, solder, connectors, wire ties, etc.
Thank you!! Very much appreciated! I will get on ordering the supplies. This is certainly a great alternative to stock and will provide alot of safety!!!
mutt
