Want to Buy Roadster foot controls, UK
simonjrwinter
Anyone want to swap their Roadster foot controls for my 2010 Classic footboards/controls.
Drop me an email or PM.
Thanks
Simon
Throws some pics on here. I am interested...:ninja:
I don't think you can very easily. I have been studying on doing just that. I have an 06 Standard and an 11 R3R. It does not look like an easy swap, if possible.
What do you see as the major obstacles? is it the levers themselves, the mounting points or the rails that they sit on,,,the rails look different but are the mount points the same. Wish I could see a set side by side...
Honestly i'ts not that big a task. Be best if you had both the bikes in the one shed together when swapping them over I'd reckon. Been done by a few Owners , pretty sure there's a post covering it somewhere.
As long as you have everything that came from both bikes you'd be ok...the abs roadster will take some fabbing to make it work and has a different brake bleeding procedure...
The foot peg tube rails on my new R3R are ok BUT with the Kuryakyn floor boards on instead of pegs, the toe brake pedal is too low and I have to tilt the floorboard forward to an uncomfortable position. The toe shifter is the same issue difficult position to get my toe under it. I need to fab up a heel brake and shifter setup. On a mission...
