I had one and it dragged in the really tight twisties. It might work better on a cement drive, but on my gravel driveway I'd just about **** my spine out my arse putting up on the stand. Other than that it was great for cleaning the rear wheel.
If its the one I have seen you will need to be the Hulk to haul it onto the stand
They supply a hand strap to attatch to the lower frame for leverage.. maybe a Scrotum Hernia too
You will need to rotate the crank angle sensor 180 degrees too to fit it other wise it will hit it , i too found it drags a bit but if you bend a cloths hanger wire to act like a hook to keep it up a bit more then it was ok , i found rolling the back tyre on a 1/2 inch thick plank made it much easier to lift or find a slight depression on the ground, having rear bars to grab onto made it much easier to lift as well good luck
once you set it up ( you get good instructions with it) it's a 5-10 minute job to take it off and put it back on, I leave mine off normally:kick: and put it on to do maintenance on the bike it's a good stable stand but to me it's a better maintenance stand
