Here is a quick write-up on the install, few things to note, make sure you are on the feed side when splicing in the wires, the same side that the thick brown wires are on. The only wire that will be spliced in from the other side is the main ignition feed wire, the white/blue fuse2 wire.
If you decide not to have both the ignition switch and the remote and just want to run on the remote then you need to cut the white/blue wire and run straight from fuse2 and NOT splice into the white/blue wire.
