Journeyman
This is one of the easiest maintenance services that you can do yourself. Seems to be a good number of questions on it, just did it today, so here goes....
See service manual instructions below (pages 184 - 185)
Loosen the Spindle bolt
Raise the bike
The strap is merely a backup.
Remove the spindle bolt. Remove the Bevel Box Badge
Remove the bearing sleeve
Remove the oil seal. Use a seal removal tool and you should not need to replace it- just be gentle.
Coat the bearings. This is a "before" picture. It's a tight fit. I cut off the tip of a Q-tip and just used the shaft to roll the grease around in there good.
Clean and grease the seal
Refit everything in reverse order. In my opinion, you do not need to replace the badge fixings (that's ridiculous). Every time Triumph has you remove a bolt that has loctite on it they say to replace it. Just clean and reapply some Loctite- blue in this case.
Torque everything to spec and you're good to go.....
Raise the bike
