rear tire getting harder to find....
It has to do with the way the tires are spliced together (overlap). The rear is setup for acceleration forces, whereas the front is designed for braking forces. I found a more reliable explanation (than me ;-) below.
@1olbull is the first I know of to promote this tire and there are a lot of other fans. I tried it once. Loved the very deep tread, but personally found the shape (more U shaped across the tire- flatter in the center) required a lot more input to get the bike to roll over in turns. Once there though it held a line really well.
Tires Directional Arrows Explained By Avon Tyres​
Published by Cyril Huze August 23rd, 2009 in Builders, Editorial and Wheels.​
Before we can talk about directional arrows you must first understand a bit about tread patterns.​
There are many different tread patterns but there is one main reason to have any tread and that​
is to disperse water. (dust, dirt)​
A tread pattern can be designed to disperse more water by making it rotate in only one direction.​
Thus, the need for directional arrows. The arrow tells you which way to mount a tire for maximum​
water dispersal. Another, less apparent reason for directional arrows is the tread splice.​
What is a tread splice? When a tire is manufactured the tread portion of the tire starts out as​
a long flat strip. This strip is wrapped around the tire and the two ends are cut on an angle​
so one end overlaps the other rather than having square cut ends.​
This overlapping point or splice offers a bigger surface area to bond together, rather than the​
small surface area provided by square cut ends. (Imagine gluing your fingertips together, as​
opposed to gluing along the entire length of your fingers laid on top of each other. Like an​
angled splice, the overlapping fingers result in a much stronger bond).​
To further ensure the strength of this bond along the tread splice the directional arrow will show​
you which way to mount the tire so that when the rider is “on the gas”; the acceleration force on​
the rear tire is pressing the splice together, rather than peeling it back.​
As for braking, 80 % of the braking should take place in the front on most bikes. Therefore, the​
front tread splice is run in the opposite direction than that of the rear, so when the rider is on​
the brakes, he’s not peeling the tread splice back.​
If you are using a tire that has a directional arrow for rear rotation only and for some reason you​
want to put it on the front, make sure it is rotating in the opposite direction so you don’t​
aggravate the tread splice.​
Avon Tyres.​
thanks for that write up very detailed but I am going to respectfully pass on this option
