R3T Handlebar Risers
Limbuck
Decherd, TN
Can you guys tell me where I can get some risers and how much height I can get away with keeping the OEM cables and wiring. I'd like for my bars to come back to me a little more. Really offset rearward risers is what I need. Can I get by with 1" or 2"? Thanks all.
Rivco risers will work. You should remove the clutch cable from the plastic shroud that holds it to the frame rail. As I recall they are either one inch up and two back or the other way around.
1 on the rivco risers they work graet no need for any new cables the clutch cable needs to be routed to the inside of the triple tree
