R3R PCV or Tuneboy?!!?
You get a key to a program, a OBDII to USB cable, and no little to no support. Check out TuneEcu before spending money on a GiPro or Tuneboy. What I would do, is use TuneEcu to modify your stock tune to remove power limitations, (by copying timing map from 4th and 5th gear to the maps for 1st, 2nd and 3rd gears, and by opening the secondaries 100%). Then I would take that money and put it toward a good dyno tune with a PCIII/PCV. You will be getting just about all you can out of your bike for your setup.
Pig9r, thanks, I am not looking for heaps of power just a tune to get smooth running and good low down torque with the stain tune system.
