R3 PCIII & GiPro Dyno Results Achieved Today
Set your hot idle speed a bit higher.
Then balance the throttles, and reset the TPS and ISCV.
A "12 minute tune-up" forces an adaption to take place, this is not the same as resetting the adaptive trims. After resetting the adaptive trims, you should force an adaption for best results.
I hope this helps.
Is there a thread anywhere that talks you through balance the throttles, and reset the TPS and ISCV ????
