lineside
Standard Bore
North Georgia
I need info on where can I order a replacement oil filter for 07 R3 on-line? Any suggestions would be appreciated, local dealer in my area never seems to have any and I am tired of waiting - . - I need to make sure that it's the same as stock so the chrome cap will fit over it.:confused: - - thanks for any suggestions.
Seriously, go to AutoZone or similar and get a Mobil M1-108 filter. It is a direct replacement and fits under the chrome cover. Costs about $8-10.
Here's a cross ref lifted from another site:
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
•Bosch 3323, about $6.
Made By Champion.
Motorcycle-Specific Filters.
* AC Delco PF2135 about $10.
* AMSOil SMF103, about $9.
* FRAM PH6017A about $7.
* Honda 15410-MCJ-000, about $12.
* K&N KN-204. Unknown price. Has a metric nut on the end for easy removal.
* NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8.
* Purolator Motorcycle ML16817 about $6. Imported, not made by Purolator.
* STP 07, about $7.
Automobile Filters, about 2.5 inches long.
* Mobil M1-108, about $12.
* Purolator Pure One PL14622 about $6.
* Bosch 3300 about $6. About 64mm, doesn't quite fit oil filter wrenches. A real pain.
* WalMart SuperTech ST6607 about $2.
* AC Delco PF1237 about $6.
* NAPA Gold 1365 about $6.
* Purolator L14622 about $4.
* STP S-02876 about $3.
Automobile Filters, about 3.25 inches long.
* Bosch 3323 about $6
* Mobil 1 M1-110 about $10
* Purolator Pure One PL14620 about $6
* Purolator L14620 about $4
* NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
* Deutsch D-370 about $4
* AC Delco PF-2057 about $6
* Motorcraft Long Life FL-821 about $4
* STP S-02867 about $3
* FRAM, Castrol, Penske 7317 about $3
It's a great idea. I use K&N air filters for the same reason, but you can buy from 11 to 45 (depending on price) regular oil filters for the price. At Triumph's recommended oil change intervals, it will take 100,000 miles minimum to pay for that oil filter. If you use less expensive oil filters, you may not live long enough for the that oil filter to pay for itself.
AHHHH more wisdom
I beleave it will pay for itself the first time I remove it for cleaning and find telltale particles on the screen that may keep me from fragging my engine, transmission . Preventive maintenance, something that has lost it's luster in todays throw away society. Plus it looks allot better than that cheesy oil filter cover.
If I were worried about my dollar return:eek: I would not have bought the beast to start with.:D
You haven't been around the forum long enough or you'd know HeR3tic has one. He's had his for a few years. I have one too but not on the Rock.
If you find telltale particles...what exactly do you do anyway? Take the bike in and tell the dealer of impending doom?
The better way is to do a spectroscopic oil analysis, something I do on a regular basis with all my engines. I just got a new engine in one of my tractors...the analysis was showing elevated amounts of iron, the shop took the engine apart and found a scored oil pump and some other things that netted a new short block....no charge.
Your dealer doesn't stock them??? Its the same part# filter for every late model triple!!
