I have a 2005 Rocket, it is not the touring model. I removed standard pipes and cat. Installed the D&D pipes and left the baffles in that they came with. I went to Triumph, and they gave me the Triumph tune for modifies exhaust with no cat. The bike runs and idles and pulls very good. I just have an issue with some decel popping. I recently downloaded Tune ecu and acquired the cable from China. I also ordered the O2 eliminator from Dyno Jet.
My question is: do I physically remove the sensor,install the eliminator on the wire, and plug the hole in the exhaust with an M16 oil drain bolt? I guess I will un-check the box in tune ecu and write the map again. Which map do you recommend, and while writing the map do you leave the engine off, ignition on, and pull the headlight fuse. Any comments or suggestions on any maps would be welcomed.
Thanks
Danny
Thanks
Danny
