Purchasing radiator cap for a 2005 Rocket 3
Winsur4
Riding Brit bikes since 1967
Buda TX
79 Bonneville, 2009 Vstrom 650, 2005 Rocket III
I just did a search for a radiator cap for my 2005 Rocket III, and could only find a cap for $52 on Ebay. I found one for $42 at a dealer, but it is special order. Is there a source for the 1.2 ATM cap?
Most of the caps I've come across that leak are because the 2 tabs bend down a bit over time if they're taken off a few times. Get pliers or tap those 2 taps up & it will fit tighter & stop leaking. Pushing down on the cap when putting back on helps.
I bent the tabs back a couple of times but the rubber washer went bad.
I have had pretty good luck getting stuff from Adept Powersports. I have also had a friendly dealer do a nationwide search for parts and a even friendlier guy spend a couple of hours searching a stock room for parts that got shoved behind other stuff.
bob
