Pulled my bike into the garage
Rich Brewer
.040 Over
Saginaw, Michigan
06 Triumph Rocket III
Was pulling the bike into the garage for the night and heard this hit the ground. It landed just front left of the front tire. Not riding till I figure it out. Any ideas?
I checked mirrors, cables, and clutch handle. Any where else that might use this??
It appears to be a wedding ring. Or is it the other thing?
that's a err conrod bolt that holds your umm front brake calliper together....o_O:roll::rolleyes:
Just sh1tting you...... look for a hole to put it back in.:thumbsdown:
it could also be the bolt that holds the tank down at front, I once noticed mine missing and quite a few km's later and having thought I had lost it found it sitting on top of rocker cover, if is that bolt it should have a washer with it, I since put a rubber washer under it so it wont work loose again, but that bolt should be Chrome/Stainless Steel so it is also possible as others have said that it is off the Radiator Shroud (there are a couple of bolts out of sight at top underneath shroud that are holding the metal grills in place) or the black plastic covers on the space between tank and headstock
