PSA - TuneECU might have a weakness on 2014+ R3s.
There is 7- 10hp difference on a stock engine, from stock filter to triples/ramair under the bearclaw depending on exhaust. Good luck with your work.
I'll admit, I'm a bit nervous about getting a CES exhaust on and tri-filters. With your 162/172 I'd imagine it's fairly easy to accidentally overdo it with the throttle
I am looking for more hp/ftlb
I see the notes about the tunes referring to this only being compatable with newer bikes... Is this still the case? Under that it says a tune has been added for 04-12. I get an error saying it is not comparable with my ecu. I have an 09 Standard.
2004-2012 version now removed following reports of it not loading correctly, working to correct the issue at this time.
2004-2012 version added
o2 On and o2 Off versions added
