rosenrot
Standard Bore
- Joined
- Sep 3, 2023
- Messages
- 10
- Ride
- Street Twin 2016
Guys I see something I don't understand when using PCV+autotune in TPS tuning mode. The AFR table is set expect for low TPS and almost everything works as expected.
When I drive in 3rd gear, I approach a certain TPS/RPM field, the trims adapt as you can see in the screenshot.
For some reason, when I go in 1st or 2nd gear, and I go to a RPM of 5000+ with a TPS of 24+, the AFR shows around 17 and I can feel that there is no power coming from the engine.
What I would expect is that the PCV adopts the AFR accordingly but for some reason it seems not to do that.
Could someone tell me if I oversee something? I didn't accept any trims yet. The "5" you see there between TPS 24 and 60 I set manually to test.
This is a Triumph Street Twin buy the way, but shouldn't have an impact on my question.
