I am not sure if this is a problem or something normal from putting on Ram Air. I notice that I get a pop/backfire sound from under the bear claw once and awhile. I am assuming this is a backfire from the throttle bodies and might be due to the ram air as I didn't hear it before it was installed. Or, did it occur but I didn't hear it due to the OEM air cleaner. Oh, I did have a TPS issue, and I pulled cleaned it and reinstalled it using Tune ECU, could this be the issue? Should I be super concerned? I am intending on installing a new TPS, putting on some pipes and doing a remap this winter, is the map the issue due to ram air? Any help/direction greatly appreciated.
