Perforated Bearclaw!
Totally unaware of this, and, as always, thanks for the info, one question, does this also apply to the Classic? thought all the bikes were the same frame and geometry?
What this combination of tyres does is reduce the rake by 1°, which is significant
Oh yes indeed
Now then "young master", I have a graphical display/drawing thing for some mental torture.
Effects on steering due to contact patch lateral displacement on banking. Disparate tyre sizes MUST effect steering. It will also affect CoG a bit depending on the crown radius.
I keep trying to visualise it in my mind - but run out of neurons. - OK time for a nap - in my defence I'm a bit poorly today.
Frank. TOTALLY - I run the same tyre sizes as Steve - 2009 Standard. The difference is notable.
But when you drop the front axle with a smaller sidewall - be aware this drops the sump and as Steve knows, this has consequences in curves.
You will need (imo) to address the forks. Various scenarios - from "cheap and cheerful" to "Pah! - It's only money".
The OEM setup makes the who bike a bit "softer" and also helps counter nose dive on braking.
It is a "can of worms" thing where one apparently unimportant change has knock-on effects.
I feel it my duty to protect baby Alicia's inheritance.
I see one side of the tire is worn down much more than the other. Why is that Paul ?
It's the camber of the road Bill.
The roads are slightly crowned so with us riding on the L/H side of the road, the R/H side of the Tyre wears more.
Also, I power slide out of L/H corners more so than R/H ones ....... No not really
