Deacon1950
do the R3T have emergence flashers?
A way to turn down the lights in the speedo?
No and no!
ok thanks 1 more u think if I changes the 7" headlamp to an LED it would stop the overheat of the ignition switch?
As long as you don't change the bulb to a higher wattage than oem you should be ok. I thought I had that issue but it was my starter.
THANKS
LOWER WATTAGE WOULD BE THE REASON TO DO IT
l have put led headlights on my R3 and all is well....Yes led should lower the load.
I have the Datatool alarm system which gives me the option of hazard flashers from the key fobdo the R3T have emergence flashers?
