ODB port 2020 Rocket 3
5011man
East Lake Atlanta Georgia
2021 Rocket 3 GT Triple Black
Hey team,
Ive looked under the seat and I don't see the ODB port for my R3. I might just be over looking it but can someone give me a hint? I want to pull the code that Ive got set.
Hey team,
black shiny plastic cover about 1 inch by 2 inches...pull up...bingo!
Thanks everyone! I found it now. I must have been tired the other day when I was looking for it.
I attached the Bluetooth scanner tool and connected. I clearly have something going on
However the scanner doesn't show any trouble codes.
The story here is I went to crank the bike and all the power went dead. I turned the switch off and back on and the clock had reset and it started complaining about my key fob being out of range. At one point it displayed the red circle alert complaining about the key.
The bike cranks and runs fine but no matter what the wrench won't go away.
Going to take it to the dealer but wanted to make sure it wasn't something simple first. Also: key fob shows full strength when I press the test button.
Have you made sure the battery terminals are good and tight? Has been an issue with these in the past... If it is cranking fine now though, might be something else. Also, what are you using to scan it? It can't show a code with having a code somewhere. If you have a generic scanner it may not find it if it is in another module, like ABS?
I'm just using the free obdlink free android app. I've got a OBD2 to USB cable. Should I try tune ECU or some other software to see if it will see the codes?
Mine did the same thing, loose battery connection. I reset the date and time but no luck. I also have the dealer tool software but it shows no codes. It will eventually have to go back to the dealer to clear.
