New to group
If this part was here in the USA I would buy it STAT. Recently someone bought a paired shaft and final drive here in the USA. They are becoming scarce. New, they cost a fortune.
So this is a common thing to happen with the rockets
It's not common but it happens if you don't maintain them. I change the rear drive oil with every oil change. Splines lube every 20K miles. Supposed to be every 10K miles.
Oil was ok and it has only done just over 31k so **** all for a 15 year old bike
Changing my rear tire this spring, so I plan to change the drive oil and grease the splines. Question on spline grease, should we be removing the shave and greasing both the output shaft splines and the splines into the bevel box or just the splines into the bevel box?
