New AntiGravity Restart Battery
its 13.43 its charging it seems these batteries if they run low they go in protect mode until fully charged, which charger is charging this battery, does the charger give charging details
Those pics were from my Rocket running. Maybe at 13.4, the Rocket system is happy. Just concerned that it is in the red. I'll check my other one that has a lead acid in it, and see what it shows. Also note the difference in cranking, from when cold, to when warmed up.
did you just install the snti gravity or did it get charged to verified charged as in charger has gone to maintain state, if not thats ok once the antigravity is fully charged it should show green but its a switch on it that kills it at 10.6 I believe to save the battery then once fully charged it goes out of protect mode, youres is the restart mine is the hd but probably same switch technology, they are great to work with so just call them if it doesn't go green after charging on lipo trickle charge
I put the 16 cell lipo on a lipo specific trickle charge when I got it, and it was fully charged when I put it in the bike. My concern is that it isn't showing in the "standard" range in either idle or high speed. I'm hoping the battery is charged enough that the Rocket charge system is at rest until the battery voltage drops lower than 13.3 ????
May have to give anti gravity a call, they would probably know how long it sat at an amazon facility and will be able to tell you whats going on with it. a 20 minute ride will tell you if youre charging, use your phone app and check as you ride a couple times but dont cut the bike off and check early in ride, i dont think youd see 13.3 which is about idle if you werent charging if you rev up it should go up a little but on the phone app you can see it in live time and youll know, anti gravity 310-527-2330 theyre in cali.
Well, forgot to update this thread. Apparently the Anti gravity battery monitor thing, was draining the battery. Disconnect it, and it is holding a charge nicely. Also, I had ordered a NoCo lithium
https://www.amazon.com/dp/B091P9QXX7?psc=1&ref=ppx_yo2_dt_b_product_details
from Amazon, for my Kawasaki 1200r, but it won't even crank it over, even after charging all night. It ain't worth a piss.
Beware: all lithium batteries are not created the same. So 100 dollar lithium battery reviews will most likely be they aint worth the return shipping. Anti-gravity should not be lumped in with nuco oh yeah xxxamazon for motorcycle parts that indeed matter.
If I had kept the box, I'd have returned it to Amazon. But I threw the box away, so I'll save it for my Gravely mower when needed. It ought to crank it over no problem. The Gravely came with a tiny lithium, that is still kicking, and with no trickle charge either!
