New...and tryin' to figure it out.
I have had lots of new bikes that were just the stripped model and much cheaper than the same one with all the bells and whistles. A couple of months later, my bike had basically the same bells and whistles, that I maybe saved a little on but then I had to order the stuff and I had to put it on---just to save a bit. Stupid really.
I have a new 2012 R3r and truthfully, when cruising the beautiful back roads of the Ozarks and Interstates, I rarely use maybe 1/3 of the throttle and 1/3 the horsepower---I mean why give it full throttle all the time anyway. By the way, at 90 mph the throttle is barely open
These Rockets are in a class by themselves but they certainly aren't Supersport bikes, so who cares about the little difference in HP and torque between the Touring and the Roadster? I've had V-maxes, Buell 1125R's, Suzuki Yoshimura Bandit's and track bikes but this Rocket to me is a nice touring mount with an attitude.
Personally, at that price I'd get the Touring model.
Sam
Very well said.... and quite frankly a much cheaper way to go. Mine is still stock but I am sooooooo tempted to put that 20227 tune on my bike. I have TuneECU loaded on my Laptop, all the drivers set, and a known to be good Lonetec cable, but have yet to pull the trigger. What tune number did you use with the TORs and filter? Does it really make it go?
What tweak do I need to do to my bone stock 2010 touring to get those 40 hp?
Download Tune ECU for free, and buy the $20 cable to plug into your bike. Find Wayne Tripp's tune for the R3T, it releases 30 hp to the stock touring without changing filters or exhaust.
if I found a new r3t for $13k I would drop everything and buy it.
Wow...you guys are not only really welcoming, but shared some great info. I figured I would post and get maybe one response. I get up to two pages of great stuff. Looks like the consensus of those that posted was to go with R3T (I have learned a new acronym). Looking forward to hearing from a few more R3R (correct?) owners that have converted their bikes to touring.
If you will pardon my new guy questions....I have one more. After owning the FJR for 5 years and having only to worry about basic maintenance (tires, oil and filters)....is the Rocket going to require more time? If so, what are the issues I should be aware of?
Thanks everybody for your good natured responses. I really appreciate the info.
j
You may want to get in touch with a member here called Watcher. Adam is evolving into an R3T specialist of sorts, and I'm pretty sure he has been having some post retirement conversations with a certain well renowned tuner that used to have a shop in Birmingham, AL.
If you look at the maintenance schedule it is pretty spread out at 10k miles intervals. The only big one other than what you have mentioned is the valve clearance check at 20k miles. Some say Triumph has up it to 30k miles with a price tag of $300 to $400. By the way..Welcome!
Just go ride it! The touring stuff won't fit the roadster. The touring is King of the Road.
