My Thoughts After A Few Hundred Miles
Yeah, baby! Let us know when available. Stealthy black finish for discreetness a preference.
I think a side mount would look good too but you would be dragging I'm sure.
The lidlox will work with the ratchet strap. One of my helmets uses that system.
Which specific model did you order: 4051, 4061, 6130?
One of my thoughts after a few hundred miles, is that the instrument panel doesn’t stay where I put it, after a little while, it just sags back to the lowest position.
My friend Erik had that on his TFC from day one. I have to say, my R collected a couple of weeks after his has had no such problem. I am surprised it was a problem at all, as this was a common concern on the Bobber too. Although that used a clamp, rather than pure pressure adjustment like the Rocket. You can tighten it, but if that doesn't work, talk to your dealer. Erik did. He said there are two torx set screws/clamps on a central clamp underneath that were actually loose.
You can feel a little more free wheel spin also in Sport.
yes you notice a difference in each mode, rain the throttle response and take off seems to be less, road mode is better, and sport mode YEA BABYYYY, the funky part is when you try to do a burn out and the system detects the spinning wheel, takes power away to stop it, then gives you the power back, hang on, because your about leave in a big hurry, overall, the bike is a riot, and if you turn off traction control, you can do burn outs for days, or until the tire blows
Don't hold the front brake for the burn out however.
