I've never had my water pump out but typically there is a witness hole to indicate if the oil or anti freeze seals are leaking on the water pump drive shaft? Depending on which seal is leaking you either get oil or anti freeze coming out of witness hole. Do our water pumps have this feature?
They water pump does have a weep hole in it. The oil seal part is just a O-ring around the pump OD . Make shure you lube it up prior to installing so it doesnt get cut.
