Hi,
I hope someone can provide some guidance. I was replacing the relay for my stebel horn, now my horn still doesn't work, and when I hooked up my stock horn, it also does not work. After I checked the button, tightened the spring just a little, I noticed that my turn signals also do not work. (no indicator on tach)
ALSO...just checked ...no brake lights. not from the front switch nor the rear switch....this leads me to believe the ignition switch is bad...or maybe the flashing relay is bad and loading down the circuit.
Could the whole assembly be bad? My high/low beam switch works. as does my dash light (high beam). Does the flashing relay also control the horn?
Very confusing....The flashing relay does not click as I would expect it to.
HMMMMmmm
WTF?!
Thanks for any help,
Jim
