rcket3
- Joined
- Aug 1, 2017
- Messages
- 19
- Location
- Adelaide South Australia
- Ride
- 2016 Triumph Rocket 3 touring.
Hi all I posted on the end of the last Rivco Riser thread but haven't got any response so will try here.
I have just fitted the rivco risers to my 2016 R3T
Re routed the clutch cable for now but have a longer one coming.
Seems like I am the odd man out but I have found that my front brake line is now too short and on full left lock is stretched very tight with no slack at all and is forcing the frame cover away from the frame.
I am scared that it is that it is under so much strain that it will either break or pull one of the end fittings off.
Can anyone recommend a way round the problem, would be easy it it weren't ABS but the line goes from the Master Cylinder to the ABS block which looks as if it is exclusively a Triumph item with the line swaged into it, which I assume means you cant just go and get one made up.
I'm wondering if there is some sort of solid extension I could use from the master cylinder to the banjo on the standard line? I only need to extend the line by 1 1/2 to 2 inches.
Am I also right in thinking that if I remove the line from the master cylinder I will have to bleed the ABS system not just the brakes.
Why can't anything be easy ?
